General => General Discussion => Topic started by: RivRunR on April 20, 2015, 12:15:48 PM
Title: Mounting an XTM 9 DI 25 T on a Terrova 55 with US2
Post by: RivRunR on April 20, 2015, 12:15:48 PM
I'm adding a Helix 5 DI to the bow, and want to mount an XTM 9 DI 25 T transducer on my Terrova 55 US2.
There's not much room on the motor, and I'm not sure of the length of the transducer, but if there is any 'wiggle room,' should I mount it toward the front, the center, or the prop?  I ask because it seems that either the fin, or the prop, might interfere with the DI cone?  I've attached a pic of the Terrova motor (I hope).
Also, I had the HBird ferrite ring installed on the US2...will it be OK to install that on the XTM DI transducer cable?
TIA
Title: Re: Mounting an XTM 9 DI 25 T on a Terrova 55 with US2
Post by: Humminbird_Greg on April 20, 2015, 12:45:34 PM
RivRunR,
the XTM-9-DI-25-T transducer is only about 4 inches long.  I would think that you would have plenty of room on that trolling motor for it.  The DI beam is not very wide from front-to-back (it is wide left-to-right though) so that should not be a problem.
Post by: RivRunR on April 20, 2015, 12:47:30 PM
Thanks Greg.
Will the ferrite choke be ok to use on the XTM-9-DI-25-T?
Post by: Humminbird_Greg on April 20, 2015, 02:05:44 PM
Yes, if you need it.  I would try it without it first.
Post by: RivRunR on April 20, 2015, 03:58:42 PM
Thanks Greg!
Post by: cache22 on April 21, 2015, 08:31:06 AM
The MK 55 has fin on the front of motor.... gives protection for TD.  Plenty of room.
Post by: RivRunR on April 21, 2015, 10:33:38 AM
Good to know, thanks for the info.
Post by: RivRunR on April 24, 2015, 12:44:38 PM
So I'm mounting the Helix DI on the bow to replace my 596HD, and it occurred to me that maybe I could leave the 596 for 2D, and just add the Helix for DI?
Both transducers on the trolling motor, the 596 on the US2, and the Helix right behind it on the XTM 9 DI.  Will they crosstalk if the Helix is running DI frequencies only?  I know that some other models continue to ping everything and just don't display it.
Post by: Humminbird_Greg on April 24, 2015, 12:55:00 PM
The HELIX 5 DI unit cannot run just the DI sonar, it will still be pinging the 200kHz 2D sonar too, so there will be a chance of sonar cross-talk.
