Software and Software Development => Other 3rd Party Software => HumViewer => Topic started by: joe p from mo on March 05, 2010, 03:40:52 PM
Was able to get out for awhile and try the DI. I had a bunch of recordings that look great on the unit and when I did them, but in the humviewer there appeared to be a bunch of interference. I went back and took a pic off of my 997 and as you can see, it is much clearer. Any ideas??
(http://i972.photobucket.com/albums/ae203/JoePfrommo/rfprob.jpg)
(http://i972.photobucket.com/albums/ae203/JoePfrommo/S00030.png)
Increase contrast and decrease brightness, or only decrease of brightness will remove some of the interference in the Humviewer image. If I have got this correct Humviewer use an "uncensored" raw recording with no noise filtering, while your unit probably does a lot of odd things with data before they are shown in the image.
Yep Rickard
You are correct about HumViewer showing the data unfiltered.
I would also recommend playing with the contrast and brightness.
/Martin
Thanks for the response. I have one more question. In the past I did not have this issue with recordings and I am using the same set-up basically??? so I find it odd that I have interference now?
The brightness did the trick, thanks for the help. ;D ;D
