Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: davidvillarejo on March 23, 2015, 02:00:31 PM
Title: 999 problem
Post by: davidvillarejo on March 23, 2015, 02:00:31 PM
Hi I have a problem with my new 999 , pressing the pedal Electric screen reading loses becomes the color palette has,Releasing the screen returns to work well , if I put the maximum speed also works well , the electric is a MotorGuide 109lbs
A someone happened the same, I need help please
Title: Re: 999 problem
Post by: Humminbird_Greg on March 23, 2015, 03:35:43 PM
Sounds like you have trolling motor interference.  Contact your local Humminbird dealer or the (U.S.) Humminbird Customer Service for things you can try to eliminate this.  There is no one size fits all fix for this as what works on one boat may not work on another, so be prepared to try several different things to help with this.
Post by: davidvillarejo on March 24, 2015, 04:29:53 AM
Hello and me and contacted Humminbird and as you say give me a list of several possible problems that may affect this weekend I will start by the simplest .
and I will tell
a greeting
Post by: Humminbird_Greg on March 24, 2015, 10:43:01 AM
Good David, maybe one of them will help.
Post by: rnvinc on March 26, 2015, 11:16:11 AM
Realize it can take one fix ... Or a series of fixes to combat your interference issue ...
Like Greg mentioned ... Every boat is different ...
