General => General Discussion => Topic started by: bucketmouth 87 on January 26, 2015, 02:42:02 PM
Title: Installing SI Transducer on Transom.
Post by: bucketmouth 87 on January 26, 2015, 02:42:02 PM
OK guys i have a 08 Trition Explorer and i want to install my 898 SI on the transom but i cant decide on a location on where to mount it.  Every where i look online seems to show a different location.  I attached a picture of my boat with 3 possible locations.  I have 2 different levels to my hull so im not sure if i install it up on the top or lower step.  Also i do not have a jackplate.  If anyone has any other options for me i would love to hear them. THanks
Title: Re: Installing SI Transducer on Transom.
Post by: rnvinc on January 26, 2015, 08:37:39 PM
Here is Triton installation info ...
http://www.bbcboards.net/humminbird-sonar-gps/241946-triton-installation-images.html (http://www.bbcboards.net/humminbird-sonar-gps/241946-triton-installation-images.html)
Most fiberglass installations usually opt to mount the HDSI xducer a little higher on the transom for protection ... And then use the AS SIDB Y cable with a "shoot thru" XP 9 20  epoxied in the bilge for high speed depth readings ...
Post by: bucketmouth 87 on January 26, 2015, 11:03:48 PM
Rickie,
So are you saying mount it to the right of the motor mount and have the middle of the transducer even with the bottom of that rib?
