		Side Imaging Forums => 598c SI HD => Topic started by: big_whiskers on January 25, 2015, 01:36:26 PM
				I just bought this unit and installed a Navionics premium hot map SD card. It works great. I was wondering if I make any recordings, or snapshots will they be saved on the navionics card or units internal memory? How do I download these to my computer to use the humviewer? thanks for your assistance. This is my 1st "Fish Finder" so I have a lot to learn but it has been great so far.
				The 598 will only allow you to record or save anything if you remove the Navionics card and put a formatted data card in its place. Its certainly possible, but its a pain because you loose your pretty maps and depth lines, etc from the Navionics card while you are recording. You will be stuck with what ever level of detail the built in base map has for the area you are in.
 Thats one of the major downsides to buying the cheaper models. To do both at the same time you need to up-grade to a unit with two sd-card slots = more $$.
