Side Imaging Forums => Onix and Ion Series => Topic started by: lcookie on November 12, 2014, 10:48:40 PM
My cables came in for the HS GPS and the aux temp sensor for my ONIX today. I hooked everything up, powered the unit up, and the unit did not auto detect either accessory. I went to the sensor menu and set them to manual but still the unit does not show them as active when I go to the data screen. Can anyone shed some light on this for me? This is a multipost from another site in case someone here does not venture over that way.
I'm still using the internal gps.i can't help here, but good luck with your new setup.you might give hummingbird a call though.
Played with it this AM and got the GPS to recognize. Still no temp.
