Software and Software Development => Other 3rd Party Software => HumViewer => Topic started by: mrj9600 on February 19, 2010, 05:37:03 PM
Title: *** HumViewer release 60 ***
Post by: mrj9600 on February 19, 2010, 05:37:03 PM
Hi All
I just released a new version of the HumViewer program. The new release is called 60.
The new release can be downloaded from: http://humviewer.cm-johansen.dk (http://humviewer.cm-johansen.dk)
As always, if you have any problems with the new release, then write a precise bug description in this thread and I will try to help you.
/Martin
Version 60 (Release date 19-02-10 23:23)
-Contrast/brightness control aded to popup menu (right click on image).
-Crop to/from, Color scheme and view type moved to popup menu (right click on image).
-Added configuration parameter for selecting 12/24 hour clock (in unit setting menu).
-Extra info shown in left side window: Date and time
-New status panel added in bottom of screen showing details in boxes.
-Extra details in status panel: Dist from boat (slant rate corrected).
-Performance of Track2D improved.
-Bugfix: Depth line text now follows chosen unit (ft/m)
Title: Re: *** HumViewer release 60 ***
Post by: sonar2000 on February 19, 2010, 07:10:30 PM
Thanks   Martin.  download and run with out a problem  1st pass I oculd tell the improvments.  Now to get into it a bit deeper.  Good fixes and a great program.  this reinforces our motto:  "If it is there we will find it. "  thanks again for all you do.  chuck
Post by: Jolly Roger on February 19, 2010, 07:19:53 PM
Hi Martin,
just downloaded and installed without problems.
Looks good and I really like the contrast and brighness control!
One question: Are the crop values in feet? I see values from 0 - 115.
Thanks a ton again Martin!!
Regards / Harry
Post by: sonar2000 on February 19, 2010, 07:29:21 PM
I cant be happier with the color adjustables.  Fantastic what this does for a scan and replay.  chuck
Post by: terry0540 on February 19, 2010, 09:10:44 PM
Martin
Thank you for all you have done for us. You have made using the Humminbird
more enjoyable for a countless number of people. The knowledge that people
like you & Robert have shared with us from all around the world is
priceless.
I have loaded it and like the new features.
Thank you Again
Terry Gibson
Post by: john h on February 19, 2010, 09:33:18 PM
Thanks Martin, love the new features!
Now I can see the recording date without putting glasses on  ;)
Post by: mrj9600 on February 20, 2010, 01:53:00 AM
Hi Martin,
Regards / Harry
Hi Harry
The crop values should be the the unit (m or ft) that  you have chosen in the 'unit setting' meny. Same unit as you see in the details box.
If not I have a problem.
/Martin
Post by: IRC Kevin on February 20, 2010, 04:21:40 AM
Wow! Brilliant, Martin. Many thanks for this.
Post by: Jolly Roger on February 20, 2010, 06:30:35 AM
Perfect Martin,
everything works fine. I used the recordings on the JURA for my first try out. These are the only recordings in which I was in "deep" water and I had the Side Range set to maximum. That confused me a bit.
In the other, "shallow" Water, recordings everthing looks like I'm used to.
Thanks again Martin, you're THE man!
Harry
Post by: caddisfly on February 20, 2010, 12:34:31 PM
What a cool si viewer,plus looks quite accurate...thanks buddy ;)
Post by: Carl on February 20, 2010, 08:49:50 PM
Just tried using humviewer 60 and am having problems with waypoints.  I can create waypoints but when i close the file it locks up.  I cannot open another file unless I totally exit humviewer and then my waypoints I created are lost.  Help.
Post by: stillbear on February 21, 2010, 08:04:15 AM
Just got the new update for my humviewer.Works an looks great.Really like the colors and how to use them.Thanks Martin.        Gary
Post by: diver651 on February 21, 2010, 08:10:38 PM
Martin,
You really do deserve a big cheer. Thanks for all of your work. Your responsiveness to our requests stands right up there with the HB folks!
Post by: George on February 21, 2010, 08:14:56 PM
Martin
Great improvements, it loads quicker and runs faster.
Post by: sow2004 on February 23, 2010, 02:24:09 AM
Martin,
Sorry, I can not download  through http://humviewer.cm-johansen.dk/ (http://humviewer.cm-johansen.dk/) here in Korea.
It'll be very appreciate if I can download your HumViewer release 60 through this conference.
Thanks in advance.
D.S.
Post by: mrj9600 on February 23, 2010, 03:05:18 AM
Martin,
Sorry, I can not download  through [url]http://humviewer.cm-johansen.dk/[/url] ([url]http://humviewer.cm-johansen.dk/[/url]) here in Korea.
Thanks in advance.
D.S.
Hi D.S.
Sorry to hear that you cannot download it directly. Is all .dk sites blocked in Korea ?
Currently I cannot add it to the download section. I think it is because the fle is 20++Mb and the limit in the download area is 15Mb.
To Robert: Is there a way to get the HumViewer setup file added to the download area ?
/Martin
Post by: mrj9600 on February 23, 2010, 04:48:00 AM
Hi D.S.
I have uploaded the setup file to: http://www.transferbigfiles.com/Get.aspx?id=3561afd6-80df-4633-a6bd-350c51ce4de2 (http://www.transferbigfiles.com/Get.aspx?id=3561afd6-80df-4633-a6bd-350c51ce4de2)
You can get it there until Feb. 28.
/Martin
Post by: Chiboo on February 23, 2010, 03:21:46 PM
Martin, In this holiday for us, I will tell two words - thanks big. Health and successes to you.
Post by: sonar2000 on February 23, 2010, 03:35:47 PM
I think the transfer big file is downloading release 67 now.  chuck
Post by: pascalfromfrance on June 06, 2010, 10:49:18 AM
hi everybody,
since i 've downloaded yesterday the release 60, nothing works. >:(
everything was ok with the previous release.
i did not change anything in my folders. yesterday my last 3 records could be scanned and today it's not the case.
every time i try to , humviewer gives this following message :
" This is not a valid humminbird Sonar recording file.
Could not find any .SON FILES FOR R00009."
HELP please because no explanation of this failure.
ps : i tried with many other recording files ...
thanks in advance.
p@sc@l
