Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: bassmasterG13 on June 02, 2014, 07:57:33 PM
i installed my 999 unit i got about a month ago. it is working great. does this unit need an update.
the time on it is an hour behind not sure if i should just change it or does it require a special update.
Daylights savings time. It got me too. ;D
There is a setting under the "Setup" tab for Daylight Savings Time...
It must be manually adjusted twice a year...(if your area acknowledges Daylight Savings Time)...
