General => General Discussion => Topic started by: ranger618 on March 08, 2014, 11:58:18 PM
Title: Ethernet and two si transducers.
Post by: ranger618 on March 08, 2014, 11:58:18 PM
I just bought an 898 to go with an i-pilot link.
I am thinking about getting another one so I can have one up front and one by the tiller.
I also plan to connect the i-pilot and both units through a 5 port Ethernet switch.
My question is. If I connect a transom mounted si transducer to the rear unit and a trolling motor mounted si transducer to the front unit, will i be able to use either transducer from either unit ?
Will I only be able to use the transducer connected to the unit ?
Will it not work correctly because the units will try to use both transducers at once ?
Thanks.
Title: Re: Ethernet and two si transducers.
Post by: Trout Bum on March 09, 2014, 08:58:53 AM
If you are connected by Ethernet you should be able to use either transducer with eiither graph.
You can choose which transducer, GPS puck, etc. to use with a specific graph by going to the Networking settings screen on each graph and making the selection.
Post by: bobcoy on March 09, 2014, 09:19:38 AM
Ranger, If you download the ethernet manual. Or use the manual on the dvd that comes with the unit. It expains all the questions I had about what is shared and what is not. Bob
