Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: fishinfever1 on September 17, 2013, 02:14:56 PM
Can you use this transducer on an 1197c and is the hdsi 180t better and why?
Welcome to the Humminbird Side Imaging Forums Fishinfever1.
Yes you can. You will need to change the Transducer Select menu to the “Sidescan” setting.
I think that the XHS-HDSi-180-T is better because it is using a higher frequency set which give a finer image. Others may have a different opinion.
Thanks Greg ,
I bought mine used and it came w/ 160t and I was wondering if there was some advantages to having this transducer
