| Display: | 480V x 800H, 8” Diagonal, 65,000 Color TFT |
| Transducer Standard: | Side Imaging/DualBeam PLUS |
| Transducer Coverage(s): | 83kHz: 60° , 200kHz: 20° , 455kHz: (2) 86°, or 800kHz: (2) 72° @ -10db; 180º Total Coveragecer |
| Operating Frequency(s): | 50, 83, 200, & 455 or 800 kHz |
| Power Output: | 500W RMS (4000W PtP) w/ Standard Transducer; 1000W RMS (8000W PtP) w/ Opt 50kHz 1kW Transducer |
| Depth Capability: | Side Imaging:150’ Down; 240’ each side; DualBeamPlus: 1500’ w/ Standard Transducer; *3000 ft w/ Optional 50kHz Transducer |
| Target Separation: | 2 1/2 inches |
| Temperature: | Included in Transducer |
| Speed: | GPS Speed Included |
| Power Input: | 10-20 VDC |
| Unit Mounting: | Gimbal or In-Dash |
| Unit Size Installed (Gimbal): | 11 1/4" W x 63/4" H x 4 1/4"D |
| Unit Size Installed (In-dash): | 10 ¾” W x 6” H x 1 3/8” D; Required Minimum 3” behind dash clearance |
| Transducer Mounting: | Transom Standard; Optional trolling motor or thru hulls available |
| GPS Receiver: | External 50 Channel WAAS/EGNOS |
| Waypoints, Routes, Tracks/Points: | 3000, 50, 50/ 20,000 |
| Cartography: | Contour XD™ Built-in, Optional: LakeMaster® & Navionics® |
| Communication: | NMEA 0183 Input/Output |
| Optional System Modules: | InterLink, CannonLink, WeatherSense, and AS WX 1 Satellite Weather Receiver |
