Side Imaging Forums => 798c SI => Topic started by: Dave Ervin on August 06, 2013, 10:24:11 AM
I need to mount my HB798ciSI on my console, or to the right of it. What is the best mount to use/buy? Where?
Thanks,
Dave
I am looking for a RAM mount model. Suggestions?
Dave
Dave,
I believe that the RAM web site has a selector guide that you can use to get the correct mount for your 798c Si unit. It may be listed as a 700 series unit.
I'm using this one, its the long arm version, pretty solid.
I Will post some pics later of my installation
The RAM-B-107U-C consists of a LONG double socket arm, 2.5" diameter round base with the universal AMPS hole pattern and connecting Humminbird/Apelco marine adapter base. Designed into the mount is a 1" diameter patented rubber ball and socket system with adjustment points at both socket ends of the arm. Rubber ball and socket technology allows for almost infinite adjustment and perfect viewing angles.
HB 798ciSI HD Ram Mount on Triton 173 Sport.
