General => General Discussion => Topic started by: yohadiko on July 14, 2013, 06:56:16 AM
My problem is that every time I turn on the screen the sound of twittering at the lighting and the screen appears only the corner for a few seconds and then completely disappeared.
Does anyone know the problem?
Intentions are gladly accepted!
Thanks in advance.
Welcome to the Humminbird Side Imaging Forums yohadiko.
I am not understanding what you are saying here. Do you mean that the display goes completely dark after it starts up?
tnx you sir
yes the scren becum blake and dark, i knoe the davice work but can't see anything on scren
I would check the power connections going to the unit yohadiko. Make sure that none are loose or corroded (dirty). You can try testing it on someone else’s boat that has a Humminbird sonar unit as most use the same power cable and a transducer that will work for the test. Otherwise you should contact your local Humminbird repair center and get your unit looked at.
