Side Imaging Forums => 898c SI => Topic started by: kipbass on June 27, 2013, 08:03:08 PM
Title: What Firmware Is Most Stable?
Post by: kipbass on June 27, 2013, 08:03:08 PM
What version of firmware for the 898 is the most stable and provides the clearest si, di, etc.. live screens?
Title: Re: What Firmware Is Most Stable?
Post by: a.altmann on June 28, 2013, 12:46:31 AM
Hi Kipbas
I too am interested to find out which version to use as it is not as clear since upgrading.
Look forward to hearing replies.
Adam
Post by: Moose1am on June 28, 2013, 11:04:23 PM
Hi Kipbas
Adam
I want to know the answer to this question also.  So please everyone tell us what your results are with the firmware you are now using or what's worked best for your 898 C SI unit in the past.
Post by: Poorman on November 16, 2013, 12:17:16 PM
I see this didn't go anywhere. Thought I would bump it up to see if anyone wants to give their opinion. I currently have the 6.74 that gives better  si clarity but worse on the 2d (bigger pixels). My last update before this was 6.40, but with it I had problems with my di giving white horizontal lines. Prior to 6.40 I had the 6.18. Please jump in and give your results and what you think is best.
Billy
Post by: flatcat_auz on November 16, 2013, 06:51:48 PM
I agree with the last observation........SI improved standard sonar degraded (pixels became bigger).
Post by: rnvinc on November 17, 2013, 12:41:01 AM
6.490 is the version most say is stable for the 898 and 998...
Post by: Poorman on November 17, 2013, 12:52:17 PM
Do you know if the better clarity on  SI come with the 6.49.
Post by: rnvinc on November 18, 2013, 09:58:37 AM
Some are saying that 6.490 is better simply because their newer software versions experience has been worse...
Some are saying the latest version is the best SI they've ever had...
There seems to be very little consistency in why either of these groups are experiencing better or worse images...
Comparing the 6.490 with the newer version yourself on your personal unit will determine if you feel one is better over the other...
The only restriction known at this time is...
It is recommended to never revert to an older version of software than what came on the unit new"...
