General => General Discussion => Topic started by: Midtin on February 24, 2013, 04:27:29 PM
Where do i go to set the time? i'm a rookie at this, can't ya tell? ;D
THANKS, MT :)
It will get the time and date from the GPS receiver data.
You don't have to double post.
Sorry, i removed one Thanks for the info
MT
You need to look under the setup menu tab to set your unit to the Local Time Zone or to turn On/Off Daylight Savings Time (which is coming up this next month).
Greg i've done that, but the time didn't change. I'm thinking it will when i get on the water and the gps finds me.It has me now here at home but i have not moved the boat.I thought it would change after i turned the unit off and back on, but it did not.
I can wait a few days and it will be right ;)
Thanks, MT
It should not matter if you are at home or on the water. If the GPS is showing a location it should have the date and time from the satellites, which you can offset the time using the menus I stated. Did you check this outside on the boat and if so was the unit running in the normal operating mode (not in a Simulator mode)?
It's inside, It shows a circle at my home and the lake which is 1/2 to a mile away. It's in NORMAL ,ADVANCED, Daylight saving is on, and in central time.
THANKS MT
