General => General Discussion => Topic started by: newkid4si on February 16, 2013, 11:13:24 PM
Title: SanDisk SD card info
Post by: newkid4si on February 16, 2013, 11:13:24 PM
Found this info on the SanDisk site.
Looks like we can use the new San Disk Ultra 30MB/s cards and save some money.
Difference between Speed Class, UHS Speed Class, and Speed Ratings (performance) for SD/SDHC/SDXC cards
What is the difference between Speed Class and Speed Ratings for SDTM/SDHCTM cards?
The speed rating measures maximum transfer speed for reading and writing images to and from a memory card, expressed as megabytes per second. However, video doesn't need as big a data pipe because the video format is a smaller "fixed stream" that uses only a portion of the data pipe.
Unlike card write speeds that measure maximum performance, class ratings measure the minimum sustained speed required for recording an even rate of video onto the card. The class rating number corresponds to the transfer rate measured in megabytes per second. Class 2 cards are designed for a minimum sustained transfer rate of 2 megabytes per second (MB/s)1, while Class 10 cards are designed for a minimum sustained transfer rate of 10MB/s2.
