General => General Discussion => Topic started by: BCLII on November 23, 2012, 09:42:01 PM
Title: 1198si & PC-10 Compatability?
Post by: BCLII on November 23, 2012, 09:42:01 PM
I was wondering if I could use a pc-10 power cord with my 1198si. It would only be used on the bench in the shop this winter for GPS maping/waypoints. I had an extra pc-10 cord and did not want to buy a pc-11 if I did not have too.
thanks
Title: Re: 1198si & PC-10 Compatability?
Post by: LocDown on November 24, 2012, 12:13:13 AM
From the looks of it, the only difference is one has a built-in RF choke.
Post by: BCLII on November 24, 2012, 07:59:30 AM
From what see/thought, it should work. The pc 10 would not filter out any interference i may get. Which is fine for what I plan on using it for this winter as a learning aid and go get more familiar with it!
Byron
Post by: Trytoofish on November 24, 2012, 08:10:23 AM
the pc 10 will work. it has no filter and I think its one gauge smaller in wire if I remember right. but the plug is the same as a pc-11
Post by: Humminbird_Greg on November 27, 2012, 12:54:37 PM
Right, the PC-11 uses 18 AWG wiring while the PC-10 uses 22 AWG wiring.  Difference is in the current carrying capability of the wire.  With the sonar shut off though I think that you will be fine.
Post by: BCLII on November 27, 2012, 02:33:00 PM
Thanks Greg, thought it would be ok . It's always good to here it.
