Side Imaging Forums => 798c SI => Topic started by: hgv on October 14, 2012, 10:24:34 PM
Title: 798 si temperture problem
Post by: hgv on October 14, 2012, 10:24:34 PM
The unit has been woking perfect when I noticed this past weekend the 798 was reading 100 degrees for the water temperature. The unit would report the correct temperature occasionally which was around 70 degrees. What shgould I check?
As i mentioned it has been working perfect until this last trip to the lake everything looks fine.
Title: Re: 798 si temperture problem
Post by: Humminbird_Greg on October 15, 2012, 01:06:27 PM
hgv,
Try connecting your 798 unit to another Humminbird transducer that has the built-in temperature sensor (most of them do).  Usually the problem is the temperature sensor in the transducer going bad.
Post by: hgv on October 15, 2012, 01:13:34 PM
Well that sucks, I have not even had it a year!
Post by: Humminbird_Greg on October 15, 2012, 01:45:50 PM
Sounds like it may be time for a warranty replacement on the transducer than.
Call the Humminbird Customer Resource folks and see about getting it replaced.
Post by: sonar2000 on October 15, 2012, 04:02:14 PM
Yes indeed.  See about a swap or a replacement. These transducers are susceptable to dings and bumps and abuse..
