Model: | ALL SI Models |
Suggested Upgrade: | Ability to create maps |
Explanation: | Lakemaster, Navionics and base map do not have a lot of lakes on them. This would allow users to record data to sd card upload to SW and create actual map on a sd card. Seems with the JO purchase of Lakemaster they could release a vector db "creator" with the LM specific format and encryption. I know Dr Depth can do a map hack for HB. It is not a real map, each lake done with this hack uses up your track point allocation on the HB unit. You are limited to the # of lakes you can add at one time. |
Added in Software Version: | |
Comments on Update: |
