Other Interest => DIY - Side Scan Sonar and towfish => Topic started by: Rüdiger on June 30, 2012, 03:25:30 PM
Depending on the depth in wich the Towfish should run, the weight can be changed.
I`m using 6 stainless steel weights a.500g that can be moved as needed on the threaded rod.
mvh
Rüdiger
that is a great idea and certainly takes a lot of work out of adjusting for depth.
Very simple and easy to adjust..
Good job.
