Model: | ALL SI Models |
Suggested Upgrade: | User definable GPS threshold |
Explanation: | Most GPSs will "lock" onto a location when the calculated position does not change beyond a certain threshold. This can give a false sense of accuracy, but it takes care of false speed readings pretty well. Larger threshold gives a steadier reading at the sacrifice of response time. Automotive units may have a large threshold - you may need to move a few dozen yards before it reports that you are moving. Smaller thresholds respond better but it can make it look like you are moving when you are not. A handheld may have a "walk" mode where it lowers the threshold so that it shows small movements. There is not one perfect threshold. It would be a nice feature to be able to adjust it to suit. |
Added in Software Version: | |
Comments on Update: |
