Side Imaging Forums => 598c SI HD => Topic started by: Murfreesboro1 on June 25, 2012, 10:54:05 PM
Title: Fish Id not working on HB 597c
Post by: Murfreesboro1 on June 25, 2012, 10:54:05 PM
I know this forum is for the bigger HBs  but has anyone had a problem with this unit as concerns the Fish ID not working?  I was in the boat and did everything that the manual said to do.  The simplest thing to do is to reset the unit defaults and then turn on the Fish ID and it should be on also increased the Fish ID Sensitivity.  Not doing it.  Thanks if has had this same problem and for your wisdom.  I just bought this unit.
Title: Re: Fish Id not working on HB 597c
Post by: Humminbird_Greg on June 26, 2012, 09:45:55 AM
Sounds to me like you have set everything correctly.
What Beam Select menu setting are you using?
What SwitchFire menu setting are you using?
What water depth is this in?
Can you make a screen snapshot of the unit showing fish but no Fish ID symbols?
Post by: sonar2000 on June 26, 2012, 03:39:51 PM
Rickie posted this on another thread.
Hit "Menu" twice to get into the Main Menu System...
Cursor over to the "Sonar" tab...
Cursor down to "FishID"...
Cursor right to bring up "Off - On"...
Cursor down to highlight "Off  - On"...
Cursor to "On"....
Post by: Johnf on July 10, 2012, 10:30:52 AM
The fish ID on my 597 ci HD DI unit was turned OFF when I received it new in unopened box last week.  As stated, it can be turned on in Sonar menu.
Post by: Humminbird_Greg on July 11, 2012, 12:56:40 PM
Is it working now?   ???
Reading the original post again; he states that he turned Fish ID on as well as turned up the Fish ID Sensitivity.  Is it showing the Fish ID Symbols now?
