General => General Discussion => Topic started by: newkid4si on May 02, 2012, 10:30:36 PM
Title: Which screen protector do you use?
Post by: newkid4si on May 02, 2012, 10:30:36 PM
And if you had to replace it, would you buy the same or a different brand?
Title: Re: Which screen protector do you use?
Post by: rnvinc on May 02, 2012, 11:14:49 PM
http://www.screenpatronus.com/ (http://www.screenpatronus.com/)
Yes.. I would use the screenpatronus again...
I found it easier to work with than the Zagg... Not as sticky...and half the price...
Post by: xSilmarilSx on May 03, 2012, 03:12:21 AM
I've got a Zagg on my 778 and 798.
I choose that brand from user on a HB forum.
A little pricey, but the product does it's job.
And super easy to install, like all screen protectors if you use
the good technique.
Post by: ITGEEK on May 03, 2012, 07:23:04 AM
For my 1197, I've got the Lexnard true vue anti-glare protector.
It's a little tricky to install without getting air bubbles under it.
It's very good, I would buy it again.
Post by: xSilmarilSx on May 03, 2012, 01:14:24 PM
The best way to not have air bubbles, and it's easy since our units are waterproof, is to put the unit horizontally and make a pool of water on the screen before putting the protector.
And make sure you have pre-cleaned the unit screen thoroughly and dried with a lint-free cloth or paper.
Myself, I use wipes made for cleaning lenses.
It's only a 10 minutes job and works like a charm every time!
Post by: newkid4si on May 03, 2012, 11:18:56 PM
Thanks to all that responded. Doesn't appear to be a dominate player.
ITGEEK-- Being that one of the main complaints about our units is the readability
              in direct sunlight; do you think the Lexnard anti-glare makes this better?
Post by: ITGEEK on May 04, 2012, 07:37:46 AM
newkid4si:
I definitely think it makes it better.
I also have a Team Waters plastic sun shield.
This hangs over the top and sides of the unit, to help
block the sun.
These accessories compliment each other nicely.
Post by: newkid4si on May 05, 2012, 12:45:24 AM
ITGEEK
         NK
