Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: choc_e on April 18, 2012, 06:46:10 PM
Just wondering if anyone has hooked up a 998c SI to a Raymarine S1000 autopilot via NMEA? Was it difficult and what wires do you connect?
I am looking at buying a Raymarine S1000, does anyone rate them? Or can anyone suggest another cheap autopilot for a twin engine cat with DF140s?
Ryan
This is what the Raymarine autopilot says about NMEA connection.
Wire Colour Pin NMEA signal at s1000 Connection at 3rd Party GPS
Brown 1 negative out NMEA --ve receive
Green 2 positive out NMEA +ve receive
Orange 3 positive in NMEA +ve transmit
Blue 5 negative in NMEA --ve transmit
But the Humminbird NMEA connections read differently in the Humminbird manual:
The following NMEA sentences are output:
DPT - Depth
MTW - Water Temperature
GLL - Lat/Lon Position
GGA - GPS Fix Data
RMC - Recommended Minimum Specific GNSS Data
VTG - Course Over Ground and Ground Speed
ZDA - Time and Date
When navigating, the following NMEA sentences are also output:
APB - Autopilot Sentence B
BWR - Bearing and Distance to Waypoint
RMB - Recommended Minimum Navigation Info
Does this make sense to anyone?
The pins are the physical connections (cable) unit to unit.
The sentence is the data contained in the information between the units.
