Side Imaging Forums => 898c SI => Topic started by: dang on April 16, 2012, 12:55:10 PM
Title: NEW 898C SET UP DOWNLOAD QUESTION
Post by: dang on April 16, 2012, 12:55:10 PM
I searched and couldn't find the answer to this ???. I just installed a 898c si in my boat, registered and seen four available downloads. My question is will this unit work without downloading any of the available downloads? or is one or more them needed for basic functions, side imaging etc. I would really like to get to know the unit before downloading if possible. Thanks for any assistance.
Dan
Title: Re: NEW 898C SET UP DOWNLOAD QUESTION
Post by: sonar2000 on April 16, 2012, 12:57:50 PM
It will work without upgrade but there are some fixes in the 6.180....
If you follow the direction on upgrading you should be fine.
1) Power on your unit
2) Restore Factory defaults
3) power off the unit
4) put in the sd card
5) power on the unit
6) wait until the update is done (can take a bit for the 26 mb file)
7) restore factory defaults (again)
 remove card
I would suggest upgrading and then go ahead with learning the unit..
You can download the 6.180 here on the forum under downloads..
Post by: dang on April 16, 2012, 01:49:25 PM
Thank you, So with the download you suggested is there any reason to download any of the others that are on the HB registration site or will this do it all?
Thanks again,
Dan
Post by: sonar2000 on April 16, 2012, 01:52:39 PM
The latest contain the previous also.
Download from HB and you will see the long name file.
On this forum it is either the long name or the 6.180.  I put both there for the time being..but they are the same..
Post by: dang on April 16, 2012, 09:02:32 PM
OK, so I installed the sd card, got the prompt for the download, started it and its been over an hour no completed prompt, is that normal? suggestons?
So in my haste I didn't read the prompt, just pushed yes.....that aborts the update :-[oops
Reloaded it and no problems. ;D
Post by: sonar2000 on April 17, 2012, 08:56:19 AM
Great...
Did you use the one fromthe forum or HB?
OK, now get out and play.  Oh, and catch some fish.. ;D
Post by: dang on April 17, 2012, 10:13:11 AM
I used the one from the forum. Hopefully I can bug out of work tomorrow and start the learning process. 8)
Post by: sonar2000 on April 17, 2012, 10:27:58 AM
OK, just curious..
Take some time and just play.
Then later you can show us some fish.. ;D
Learn the snap shot feature so if you have problems you can post a picture along with your concern..
