		Side Imaging Forums => 798c SI => Topic started by: maachuu on March 18, 2012, 09:30:38 PM
				of months ago and I find that I cant see anything when using the DI and SI, seems to be a faint picture there but cant see it in the sunlight even with raptorcap on it. also notice that the colors will not change to blue, green and other colors, the only thing I can see a faint picture on is one of the amber colors. anyone experienced this before ? I upgrade sw to 5.84 before I used the unit and just now finished reverting back to 5.45sw but havent had chance to get on water to test. when I bring it in the house and put in simulator, the colors change just fine
 Thanks in advance
 maachuu
				maachuu,
 Make sure that you are using the SI Color menu on the full Si sonar or full Di sonar Views.  This is a separate menu from the Sonar Colors menu for the 2D sonar that is found under the Sonar menu tab…
