Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: tommyboyrn on January 31, 2012, 07:15:34 PM
I downloaded humviewer but was looking for something else to play back recordings from the lake..........
Anyone got anything else they ise to playback their recordings, if so post the link thanks
Tom
Hi Tom
You can use DeepView http://www.deepvision.se/download.htm (http://www.deepvision.se/download.htm).
Look here at this forum under Software Downloads, you can find the software Yellowfin and SI View. Both work well, but for that you need to convert your records until you find the converter correspond there.
mvh
Rüdiger
many thanks, will look at it
Yellow fin is another 3rd party viewer download it from this sight.
do you like yellowfin better than hum viewer? it may just be my inexperience with humviewer as to why i was looking for something else
Our two choices of vieweers are humviewer and then yellowfin. If I want a particular area I use the deepview..
All will be good.......and much better than a review of the recording on the unit... Too small of screen and way too slow. Also you can go forward and backwards very easily as you can in the other programs. Makes youy wonder why HB did not write a viewer as other mfg'rs do....
many thanks.
Tom
Tom yes I like yellow fin. Gary
