Side Imaging Forums => 898c SI => Topic started by: T.G on October 17, 2011, 04:44:30 AM
Title: transducer select
Post by: T.G on October 17, 2011, 04:44:30 AM
Hi, i`m trying to find out some info on which setting i should put my transducer on,in the sonar set up menu there is the option "transducer select",there are 7 set up options;hi-def sidescan,compact sidescan,sidescan,quad beam,dual beam,dual 50/200,universal sonar.Can some one please either tell me where i can find some info on this or please explain which one i should be using, am i suppose to be switching between them for different sonar choices,ie;sidescan,2D, down scan or do i just leave it on the one setting for all?I am fishing in saltwater in a max depth of 35ft if this helps thanks in advance.
T.G
Title: Re: transducer select
Post by: stillbear on October 17, 2011, 05:48:20 AM
I use HD Side Scan only. Gary
Post by: ITGEEK on October 17, 2011, 11:58:09 AM
With the High Definition Side-Scan option, you
will have everything 2d, Side-Scan, DownScan.
The one you need to use should be the default
options for your unit.
Post by: T.G on October 17, 2011, 09:40:33 PM
thanks guys , i will leave it in hi-def sidescan.
Post by: sonar2000 on October 18, 2011, 02:38:56 PM
Hi-def sidescan  definately...
