Side Imaging Forums => 798c SI => Topic started by: Wylezalek on October 09, 2011, 08:16:27 AM
Title: Works the 898CX SI with 2 sonar on a Y-cable
Post by: Wylezalek on October 09, 2011, 08:16:27 AM
Hello.
Works the 898CX SI with 2 sonar on a Y-cable. If it works, which the sonars?
Thank you.
Best Regards
Peter
Title: Re: Works the 898CX SI with 2 sonar on a Y-cable
Post by: Humminbird_Greg on October 10, 2011, 10:43:01 AM
Which two transducer and Y-cable are you wanting to know about Peter?  There are two different possibilities here:
1.  The Y-cable that uses the Si sonar and water temperature from the Si transducer and the 2D sonar from a DualBeam transducer.  This is the AS-Si-DB-Y cable.
2.  The Y-cable that uses the Right Si sonar, 2D sonar and water temperature from the Starboard side mounted Si transducer and the the Left side Si sonar from the Port side mounted Si transducer.  This is the AS-Si-LR-Y cable.
