Side Imaging Forums => 898c SI => Topic started by: jules2003 on April 25, 2011, 05:44:06 AM
I exported all my waypoints and routes from my HB 898 to the SD card. When i insert the SD card or restart the unit again, following message is on the unit:
No navigation data found.
What´s wrong?
Regards Michael
Are you sure it didn't say 'No New Navigation Data Found?'
I think the unit compares what's in the internal memory to what's on the SD card and will put any new data into memory.
As long as you just exported your Navigation data, it just copied what's in the system memory to the SD card. It will retain what was in the system memory.
If you deleted your Navigation data at any point, then it wiped out what was in the system memory.
