Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: Trytoofish on February 08, 2011, 05:48:20 PM
What changes were included in software version 5.320?
If you have a:
* 1197C SI
* 997C SI
5.320 includes:
The new Contour Mode has been added. This Mode is part of the SI Enhance Menu in the Express Sonar Menu.
[attachment=1]
Contour Off shows you the standard Side Imaging view
[attachment=2]
Contour On removes the water column and shows you a flat representation of the bottom.
[attachment=3]
Addition of Side Imaging range lines
[attachment=4]
Side Imaging Navigation - When you are Navigating (GOTO) to a waypoint the boat icon on the top of the side imaging screen will try to show you the direction to the waypoint. This icon will move around to provide the direction to the waypoint.
[attachment=5]
Addition of Down Imaging™ Zoom
[attachment=6]
plus a fix relating to DownImaging bottom lock, DownImaging shallow water depth detection, DownImaging sonar recording/playback at shallow depths
If you have a:
* 1197C SI
* 997C SI
* 957C
5.320 includes:
Resolution to Interlink issues affecting GPS connectivity and waypoint sharing, along with changes to: importing from an MMC card, setup menu options, exit during remote sync in progress, GPS Course and auxillary temp alarm. Both units connected through the Interlink must have 5.210 software or higher loaded onto their units for these changes to work.
Chart layers were added, custom chart menu display was fixed along with minor Downrigger fixes were made for those with Cannonlink.
If you have a:
* 1197C SI
The Auxillary Temperature information box was added.
Trytoofish,
Thanks for posting the information from the Humminbird FAQ section.
I have edited and attached the images and video here for everyone to see.
How To Change Your SI Unit To Contour View.MP4 (http://www.youtube.com/watch?v=6MTz58oDdGU#)
Thanks Robert
Much better,I hoped the images would copy/paste but no such luck.
also I could not get the video link in the FAQ to work. Is that where you got it.
No, the link for the video was not correct. The video was also on youtube.
Why did they not add the 898 unit as well for the folks that have those. I thought the compueter ships in the 898, 997 and 1197 were basically the same...or that is what we were told last year in a seminar hosted by a Humminbird tech. Also, i do realize the 898 and 997 have the same pixels with the 1197 being different...is that correct ?
calli,
I posted a detailed response in your other post. Short and simple, no they are not the same. Each unit has slight differences that make it necessary to have different updates. Especially in the new models vs old models. They actually changed the OS software in the new models.
http://forums.sideimagingsoft.com/index.php?topic=2090.msg11444#msg11444 (http://forums.sideimagingsoft.com/index.php?topic=2090.msg11444#msg11444)
Good Luck,
Trytoofish, I have a 997c SI Combo on the console & on the trolling motor I have a 798CI. They're both hooked into each other w/Interlink. Now when you posted that both units must have the 5.210 updated version for the Interlink to work properly...I went online to Humminbird to view my profile...the 997 update available is the 5.320 version & the 798 update available is the 5.210 version. So are you just saying that both units have to have at least the 5.210 or higher versions for the Interlink to work correctly? Thanks for all of your help
Irishrover,
For the InterLink to work, both units would need to be running software that is version:
4.995 or lower
5.210 of higher.
But the 5.210 software (and higher version numbers as of today) has not always worked either… So I would contact the Humminbird Customer folks and ask for the 4.995 software for each of your units until they can come out with a newer version of software that works better with the InterLink.
Irishrover
you should be able to get the older versions here
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=1 (http://forums.sideimagingsoft.com/index.php?action=downloads;cat=1)
