Side Imaging Forums => 898c SI => Topic started by: Rüdiger on February 07, 2011, 10:03:52 AM
Title: SD-Card for 898c SI
Post by: Rüdiger on February 07, 2011, 10:03:52 AM
Hi :D
Which type and quantity of SD-Card kann the 898vc SI read ( SDHC....) ?
Mvh  Rüdiger
Title: Re: SD-Card for 898c SI
Post by: chet on February 07, 2011, 01:06:28 PM
Sandisk 4,8,16gb extreme III class 10 which is read and write at 30mbs. I just used my 4gb for 4 hrs  on the boat amd wasn't even close to being full of data.
Post by: Kees Michielsen on February 28, 2011, 09:35:15 AM
From the FAQ section on www.humminbird.com (http://www.humminbird.com) :
Are your units compatible with the newer SDHC cards?
The answer to this question does depend on the model number of your product and also the software version you have loaded on your unit.  They are compatable with all 700, 900 and 1100 series products with color displays with softare version 3.7x0 or higher, On monochrome 700 series you would need version 3.8x0 and higher.  The highest capacity we support is 32G.  Older versions of software or older products will not be compatable.
