Side Imaging Forums => 798c SI => Topic started by: mt72916 on February 05, 2011, 10:43:51 PM
Title: 798 HD SI DUAL SETUP
Post by: mt72916 on February 05, 2011, 10:43:51 PM
One of the possibilities I am considering is mounting a 798 HD SI on a ram mount at the console and at this time I can only afford one head unit.  I understand that I need to mount the SI transducer to the jack plate and a 2d transducer in the bilge for high speed 2s sonar and a “Y” cable for just the console configuration.
 What would I need to order for an extra setup to set this unit up to move it to the bow on the trolling motor? I would like DI an 2d sonar at the minimum there.
Title: Re: 798 HD SI DUAL SETUP
Post by: Humminbird_Greg on February 09, 2011, 04:59:40 PM
That depends on what you want to do for the transducer: mount a second CSi transducer on the trolling motor or use the ones you already have on the transom (and inside-the-hull)?
For both you will need:
PC-11 Power Cable
MS-M Quick Disconnect Mount
To install a second CSi transducer you will need the XTM-9-Si-180-T transducer.
To use the transducers you have you need a Unit Switch US2-W.
Post by: mt72916 on February 09, 2011, 07:45:17 PM
well after much studying and agonizing
I bit the bullet today bought these from BBG Marine
this is my first color unit
Humminbird 798 ci HDSI  #407970-1
Humminbird XTM-9-HDSI-180-T
Navionics hotmap Premium South
Mount case covers MC-W
AS SIDB Y splitter cable
Ram mount Ram-107U
DBK2 2nd station ducer kit
just going to swap head unit positions as necessary
plan to swap at humminbird the std compact transducer for XHS-9-HDSI-180-T  for the transom
and also swap the MS-M for the  MS700-E  2011 798 HDSI mount
and i should already be set up for an upgrade extra CHO someday.
just got to get some tranducer shield products now.
