General => General Discussion => Topic started by: Enufzed on January 25, 2011, 01:51:18 AM
Title: Quadrabeam for 898c SI
Post by: Enufzed on January 25, 2011, 01:51:18 AM
Hi Guys
Will the Quadrabeam Transducer XNT-9-QB-90 T give me any great benefits than the standard transducer that came with my 898cx SI. I mainly use my HB for fishing in both shallow river and deep sea.
Title: Re: Quadrabeam for 898c SI
Post by: Humminbird_Greg on January 25, 2011, 10:39:26 AM
About the only advantage would be if you cannot get Si readings at higher than trolling speeds on your boat and you bought and could install the inside-the-hull version of the QuadraBeam (XP-9-QB-90-T).  You would be able to get sonar readings from a wider (left-right) area than you can with the standard 200/83kHz 20/60 degree DualBeam portion of the HDSi transducer.
