General => General Discussion => Topic started by: smoke20 on September 26, 2010, 10:30:32 PM
I have a 898c Si combo the three times I have been out the gps only shows have of the lake i am on the first time I was at Priest lake in northern Idaho
N 48 30.987 W 116 53.228 and it only showes half of the lake and this last week I was on the Columbia river in Wash. state N46 52.617 W 119 57.847 and It would not show any of the river it would just leave a trail on a brown back ground I have try the zoom in and out and nothing . Do I not have something not set wright and I can not find the contour XD can some one help Thanks
Smoke20
I cannot say for sure, but checking my 1197 NVB and Navionics Hotmaps Explorer program I do not see that Navionics has charted out your lake.
I do not have any Navionics cards covering your area, you might want to call Navionics to see if they cover your lake.
I do not believe that they are charting rivers especially since rivers are very dynamic with depths changing frequently.
You may want to purchase Navionics Hotmaps Explorer for $19.00 to view the lakes in your area ( Priest lake is not covered).
Hey guys please correct me if I am wrong.
Thanks for getting back to me so if I do not have a card in the unit it will not show any lakes is that wright , so the unit has no lakes in it from the fac. so the only way to use the contour xd is with a navionics card is that wright . so when I go out to a lake it is not going to show that there is a lake there unless I have a card in it its not like a gps in a car that showes everything thanks ???
Contour XD is the current base map we are installing in the 898c Si units (it took the place of the UniMap we used as a base map before). Some of the Contour XD maps do have depth contour lines on them although not at the same level as a Premium HotMaps or LakeMaster mapping card will have. If the lake you are on is covered by the Contour XD base map than it will be shown, if not it will show it as land unless you have purchased and installed a map card that has this data on it.
As Greg pretty much stated is all HB SI units have Contour XD installed as a minimum.
My unit is a NVB unit and I have not viewed the new Contour XD maps.
Again not sure if the lakes you use are covered by Navionics, you might want to check with them.
If you post the lakes you fish I will try to check on them for you. Somewhere Navionics posts which lakes are covered.
The list of waters with Contour XD is on this site in the software download section.
http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=32 (http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=32)
Smoke20
Contour XD have 17 lakes listed for Idaho and the Navionics Chip have 49 lakes listed.
Below is the list I found opening Wayne's post and on Navionics site for the 2010 chips.
Hope this helps
Idaho (17)
Anderson Ranch Reservoir Elmore ID
Arrowrock Reservoir Elmore ID
Bear Bear Lake ID
Blackfoot Reservoir Bingham, Caribou ID
C J Strike Reservoir Elmore ID
Cascade Reservoir Valley ID
Coeur d'Alene Kootenai ID
Daniels Reservoir Oneida ID
Dworshak Reservoir Clearwater ID
Lucky Peak Boise, Elmore, Ada ID
Mackay Reservoir Custer ID
Mann Creek Reservoir Washington ID
Montpelier Reservoir Bear Lake ID
Palisades Reservoir Bonneville ID
Pend Oreille Bonner, Kootenai ID
Redfish Custer ID
Ririe Reservoir Bonneville ID
Idaho (49)
Alturas Blaine ID
Bear Bear Lake (ID) Rich (UT) ID
Belvidere CreekValley ID
Cache Creek Lakes Lemhi ID
Copper Shoshone ID
EchoIdaho ID
Elizabeth Clearwater ID
Ellie Clearwater ID
Fernan Kootenai ID
Fish Clearwater ID
Gold Shoshone ID
Heathe Shoshone ID
Ice Clearwater ID
JackClearwaterID
Lucky Peak Boise
Elmore, Ada ID
Mann Nez Perce ID
Mush Clearwater ID
Palisades Reservoir Bonneville (ID), Lincoln (WY) ID
Payette Valley ID
Pend Oreille Bonner Kootenai ID
Pete Ott ClearwaterID
Pettit Blaine ID
Pot Clearwater ID
Redfish Custer ID
Silver Shoshone ID
Snowy Top Boundary ID
Soldiers Meadow Reservoir Shoshone ID
Spring Hill Reservoir Latah ID
Stanley Custer ID
Steep (Lower) Clearwater ID
Steep (Upper) Clearwater ID
Tille Clearwater ID
Tin Shoshone ID
Waha Nez Perce ID
Williams Lemhi ID
Yellow Belly Custer ID
