		Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: ElvisMarcy on August 02, 2010, 04:59:05 AM
				I just bought a 997 and 788, i was wondering what you alls recommendations on batteies were. I have a three bank set up, two deep cycle for TM and 1 for cranking. I was told that I should use a deep cycle for cranking and running my birds. Or would a Starting battery be just as good.  Whats some good makes and sizes? All comments are appreciated.
 __________________________________________________
 Struts (http://www.autopartsgate.com)
 Shock absorber (http://www.autopartsgate.com)
 Ford quick strut (http://www.autopartsgate.com/ford.html)
				If the HB is the only item on a battery almost any 12 rechargeable will do.  We use our portable 1197 on a 12 volt motorcycle battery.  About 5 hours of run time.
 If you share a battery then it needs to stay charged. Cold crank is not an issue.
