Side Imaging Forums => 798c SI => Topic started by: ROBINVL on July 09, 2010, 01:56:42 AM
Title: glued transducer
Post by: ROBINVL on July 09, 2010, 01:56:42 AM
I moved my 798ci to a new boat and the dealer glued the transducer inside the hull. Had to have them remove it and reinstall it on the transom. I have used it three times since the change and now I have no SI. Will glueing ruin the ducer?
Title: Re: glued transducer
Post by: sonar2000 on July 09, 2010, 07:23:30 AM
It could have.  but also check the connectors for bent pins.  Also the cable to make sure it was not cut or abraised.
Try a buddies unit on your transducer and also your unit on his boat transducer.
Post by: RGecy on July 09, 2010, 05:53:55 PM
You should not have been able to get very good if any SI when the transducer was glued in the hull.  Can you post a picture of the transducer?
The gluing should not have ruined it if it was cleaned off nice and there is no epoxy left on the transdcuer.
