Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: RV Sam on June 08, 2010, 12:36:48 PM
I have saved tracks. I have deleted tracks that I knew I would never want again. But, when I shut the unit down with my days run still showing it is still there the next day. I now have a LOT of those showing on my unit. The only thing I can see is for clearing a current track and deleting a saved track. Did I see something for Delete or Clear ALL Navigation ? Will that delete my saved also. Thanks.
Yes, Delete All Nav Data will delete the saved tracks as well. Don't forget, this will Delete ALL of your tracks, routes AND Waypoints!
If you Clear the Current Track you should only be left with the Saved Tracks. Then you can delete those one at time.
