Side Imaging Forums => Solix Series Units => Topic started by: proskeeterman@comcast.net on May 03, 2024, 07:01:30 PM
Wanted to know if slo mo fuses are necessary on the 12 n 15 Solix?
While slo blow fuses are recommended, I’ve never found a reliable source for getting them ...
Correct size fuse as indicated in the installation manual would be more important ...
I did find slo blo (tube type) fuses, so if I can use them, that's better Yes?? But a regular 5a for the Solix 12 and a 7.5a for the 15, will work, Yes? Do you recommend putting them closer to the unit or to the battery? Sorry for all the questions but I'm just trying to do this as right as I can. Really appreciate you guys and this site.
Installation manual says “as close to the battery as possible” ...
https://humminbird-help.johnsonoutdoors.com/hc/en-us/articles/9216210775831-In-line-Fuse-Installation
SOLIX 10 and 12 =5amp
SOLIX 15 = 7.5amp
