Side Imaging Forums => Helix Series Units => Topic started by: John Coward on May 10, 2022, 03:28:03 AM
Title: Helix 7 MSI GPS G4N
Post by: John Coward on May 10, 2022, 03:28:03 AM
Hi. Does anyone have the newest Helix 7 MSI GPS G4N. If so, could you tell if your unit has the side and down image view together. Humminbird technical are telling me they have removed this view from this unit and replaced it with SI/SI view instead.
Humminbird told me to reset my unit back to factory settings, and then put it in advance mode, make sure the correct transducer was selected and try again, and when I had done all these things and took a video of me doing this and sent it to them, they then tell me my unit does not have this view.
I'm left wondering if they are fobbing me off.
Best wishes
John.
Title: Re: Helix 7 MSI GPS G4N
Post by: Randysbird on July 11, 2024, 11:53:55 PM
Yes it does
Works great
Post by: Kenai on July 13, 2024, 09:01:13 PM
Best wishes
John.
Try to press and hold view button until it shows you a view express menu with possible views. Also, try to double-check if that view is not hidden under view tab in menu. Additionally, you can try in simulator. If there is a problem with the transfer, it will not occur in the simulator.
If that doesn't help, I would go to the nearest shop and try it on a different unit.
