Side Imaging Forums => Solix Series Units => Topic started by: Luke222 on April 17, 2022, 09:27:18 PM
Hi,
I have a solix 15 GN3, worked fine until last trip. Once I turn the unit on, there is no depth reading. The only way to fix this is to put the unit in standby mode, and then out of standby and then it reads that transducer is enabled, and i get a read out. Any help would be appreciated.
Cheers
Well that’s an unusual gremlin ...
From the Home screen select Restore Defaults ...
Then in the right pane select Restore Sonar defaults ... test the results ...
If that doesn’t fix the issue try a full Restore Defaults on that same page ...
No wuckers, will suss this out later. 🤞
