		Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: ATB1134 on April 06, 2010, 05:27:11 PM
				I CAN'T SEEM TO GET FISH ARCHES WORKING ONLY THE ICONS? ANY HELP
				If you want the Fish ID on, you are fine, else turn it off in the Sonar Menu.
 As for the fish arches, you may need to tilt your transducer down a little (or up).  Can you post a snapshot of what you are seeing on the screen.  Preferrably with Fish ID off, and this will help us see whats going on.
 Good Luck and let me know if that helps,
				WILL POST PIC AFTER THIS WEEKEND
				Pretty sure it will not show arches with fish id in the ON mode. When you turn it off, it will reflect arches vs those little little arcade fish. ;D
 Select menu tab and then Sonar Fish ID OFF.
				Actually when the user selects to show the Fish ID Symbols we show them over the processed sonar (what you would normally see), we do not cover up the sonar reading with the Fish ID Symbol.  Turning the Fish ID Symbols off just eliminates the fishy above the arch (if your unit was going to show the fish with an arch).
