Side Imaging Forums => Helix Series Units => Topic started by: cade on September 16, 2018, 03:50:15 AM
Is it possible to disable the 2d sonar 200/83khz but still use SI and DI on a helix 10 mega g2n?
The reason for this is I also run a furuno sounder and the 2d sonar on the humminbird creates interference with the furuno which I would like to prevent.
Unfortunately 2d cannot be shut off because the unit uses the 200kHz 2d for digital depth ...
Is it possible to select a different frequency on the Furuno ...??
