Side Imaging Forums => Solix Series Units => Topic started by: Skeeter07 on September 09, 2018, 07:09:38 PM
Title: Solix units stopped networking
Post by: Skeeter07 on September 09, 2018, 07:09:38 PM
Was out fishing and everything was working and then half way through day 360 stopped working and gps and sonar stopped being shared along with mapping not be shared.  5 port switch is under console everything was still plugged in but when networking issues started I was hearing ticking sound coming from under console.  Anyone thin 5 port went bad?  Is there a fuse for 5 port?  Low voltage?  Looking for help and all was wired from basscat factory.  Thanks.
Title: Re: Solix units stopped networking
Post by: rnvinc on September 10, 2018, 07:57:28 PM
I would hope the factory wired power to the AS ETH 5XPG with a fuse  ...
Can you trace the the power wire to where they connected it to 12v power  ...??
Post by: Skeeter07 on October 08, 2018, 09:23:50 AM
So haven't taken boat in to get networking problem above checked out.  But went out yesterday and to my amazement 360 and units were linked again.  Nothing changed except deleting all nav data on each machine.  Anyone had this happen to them? Been told by humminbird they are working on another update for solix units.  Sure hope this helps with this and not having to finesse settings to get depth finders to work correctly.  Spend thousands of dollars to have these issues.  No wonder you see a lot of ppl going to Garmin and Lowarnce.
Post by: rnvinc on October 08, 2018, 10:40:08 PM
We have seen corrupt Nav data causing weird issues across many models  ...
Note if you edit waypoints: only use letters and numbers. Do not use spaces or special characters  ...
Post by: Skeeter07 on October 09, 2018, 12:34:46 PM
Thanks for the info Rickie.  Puzzling sometimes.
Post by: hollada on October 28, 2018, 10:43:45 AM
I have hundreds of waypoints with spaces in the name.  I also have sporadic strange problems with my solix 12.  What kind of issues are traceable to spaces in a name?  Anyone know if HB is doing anything to address this?
