Other Humminbird Products => Accessories => Topic started by: bbordeau on April 11, 2012, 08:44:16 PM
I see two separate model numbers online by various vendors - what is the difference between the two units?
Model Numbers are - 406930-1 and 1903040.
Brian
the 406930-1 is the HB model number.
I found the second number 1903040 as a cannonlink but was from the HB parent company Johnson Outdoors..
which store did you buy it from?
chuck
I have also found 1903040 on HB..
So disregard my comments..
I dont know what these numbers mean.. :P
Hopefully some one does and will let you know..
Sounds like a question for the folks from Cannon… but i will try and help anyways.
Let’s see; the Cannon web site lists the CannonLink as part number 1903040
The Humminbird web site also now lists it with the same part number. The 406930-1 part number was the part number that Humminbird used when we built and marketed the CannonLink. That is now being done by Cannon, so I don’t know if there were any changes to it or not but either part number should work.
You shouldn't have sold it but rather kept it in Johnson outdoors.., ;D... :o... ::)
OOOPPPSSS I think that Johnson Outdoors still owns cannonlink. Not HB. You guys(hb) still should have kept it..>
Cannon downriggers is still owned by Johnson Outdoors, Inc. This is the same parent company that owns use and many other companies.
Thanks guys, I haven't bought it yet, I was just looking online and doing some background research on it and came across the two numbers...
