Author Topic: Where to save raw data to be processed?  (Read 1946 times)
Offline GM
  • Software: None
  • Accessories: None
« on: October 04, 2021, 09:24:54 PM »
After a while reading several posts I am still confused about where to save raw data obtained during acquisition (AutoChart live with Solix, helix, apex, etc). So, I must buy Zero line cards for this or I can simply use regular card disks such as those from ScanDisk. Also, I read that files saved to zero line cards are only in ACU format, while those saved to other cards (eg. ScanDisk) are in SON/DAT format, is it right? Any hint is appreciated.
Best,
GM
Online rnvinc
Re: Where to save raw data to be processed?
« Reply #1 on: October 05, 2021, 11:21:30 PM »
All the AutoChart products must be used with the Zero Line card  ...
A regular SD Card is for Nav data, ScreenShots, or recording Sonar  ...
A recording on a regular SD Card can be imported into the AutoChart PC program to create custom maps  ... but must then be exported to a Zero Line card to be used in the HB unit as a map card  ...
Offline GM
  • Software: None
  • Accessories: None
« Reply #2 on: October 05, 2021, 11:40:39 PM »
Thanks Rickie, I understand that ReefMaster will use SON/DAT/HT raw data for further processing/analyses (and also viewed simultaneously as in here
, for example the 2D echogram with the mosaic), which means that the raw data (the one I am interested in) should be saved to SD cards, please correct me if this is wrong.
« Last Edit: October 05, 2021, 11:53:09 PM by GM »
Online rnvinc
« Reply #3 on: October 06, 2021, 10:24:47 PM »
You are correct. Sonar recording is written directly to a regular SD Card (32gb max)  ...
Last post April 23, 2012, 08:52:05 AM
Last post May 22, 2012, 12:40:11 PM
by ITGEEK
Last post February 27, 2013, 12:23:31 PM
by tigerfire
Last post May 29, 2013, 10:49:29 AM
Last post January 28, 2014, 02:32:49 PM
Last post May 29, 2015, 09:41:49 AM
by Thermite
Last post April 28, 2016, 01:47:43 AM
Last post October 05, 2021, 11:16:34 PM
