Side Imaging Forums => 797c SI => Topic started by: jagert59 on August 26, 2011, 02:02:45 PM
Bought a used 797c2 si and obviously when I power it up it displays the previous owner's name. Is there any way to change this? Thanks
Yes...hang on a minute and i will get the procedure.
Jolly Roger posted this in the FAQ's..
Here is the link to it..
It is easy to change or modify..
http://forums.sideimagingsoft.com/index.php?topic=719.msg3345#msg3345 (http://forums.sideimagingsoft.com/index.php?topic=719.msg3345#msg3345)
Thanks, I give it a try tommorrow!!!
Great.....let us know if you have any trouble...........Chuck
Took me a little longer to get around to it, but worked great! Will this work for my 997csi also? Thanks again! Tom
You could or you could just use the HumminbirdPC program:
1. Insert the SD card into your computer’s SD card reader.
2. Start up HumminbirdPC.
3. Select the SD memory card icon on the left side of the screen.
4. Select the Green button with the “A b C” on it.
5. Type in your preferred text in the allowed areas.
6. Press the “Save” button.
7. Disconnect the SD card from your computer.
8. Install the SD card into your Humminbird unit.
9. Power on your Humminbird unit and it should automatically load the profile data changes.
