Images, Snapshots and Videos => Side Imaging Videos => Topic started by: phmadeira on April 08, 2015, 11:11:51 AM
Hello
My goal is to record the Side imaging video
and to view it latter ?
So what is the best / cheapest unit for this ?
Like to record about 2 hours, is there a limit recording time , or only size of the SD card ?
thank you
You can make a Sonar Recording with any of the Side Imaging model units. So the one with the smallest display size will typically be the cheapest. Currently I think that would be the HELIX 5 SI-GPS but you should check with a dealer to be sure. You could use a used Si unit from someone else or maybe find an older out of production model as well.
Recording time is limited by the capacity of the memory card used. The larger the memory card's capacity, the more hours you can record to it. It is recommended that you keep your recordings short though (~30 minutes) so in case there is a problem with that recording it does not spoil hours of work. It also makes it easier to move through and manage the recordings so you are not stuck looking at endless hours of recordings that don;t have anything of interest in them.
