Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: billycrg on May 07, 2011, 01:19:10 PM
I am installing a second transducer through the hull for 2d with my 1198 c SI at higher speed. I have a XNT9DIT transducer that came with my 788ci HD DI unit. Will this transducer work with the 1198 and the Y cable
Yes it will but all that should work correctly would be the 200kHz 2D sonar.
