Other Interest => DIY - Side Scan Sonar and towfish => Topic started by: Rüdiger on October 16, 2011, 04:49:26 AM
Hi
Now the work is done. For this towfish i used Roberts idea with some modifies.
The ballast ( 2 kg stainless steel ) on the outside off the towfish works also as a careen and a transducherprotector.
The 36m cable ( 3 extension cable EC W30 ) goes trough the tube and is fixed to the end. I hope, if the fish gets caught in the tow, the fixingpoint off the cable brakes first and so its get be possible to draw the fish backward out.
Material
Tube: PVC 50mm x 2,4mm
Plate: Bubble-PVC „Kömacell“
mvh
Rüdiger
Hi,
Also, the color is close to the traditional Swedish Grey that was used on all machines from this country some decades ago ;-) It looks like a very accurate design. I look forward to see some images!
Grattis!
Hi,
Nice job!!! Good luck and post some pix.
Hay Robert, I told ya' I would not be the only one. The tubes work well.
Wow, geiles Gerät Rüdiger!
Lets see some pictures. I'm back to base since a couple of weeks, but the lake is so low and foggy that I didn't had a chance to do anything on the water. I bought a small dinghy with a trailer and a small outboard engine. I will try if it is sufficient for winter scanning since the big boat had to go in winter storage.
Regards from the south / Harry
Harry, welcome back and safe..
Post some picture of the new setup on the dinghy.
And as usual some of your great pictures that you get with your setup..
Harry, Hope all is well. How was the sandbox? Welcome back!! Thank You!! Roddy
